Faulty ABS Module
  • Faulty ABS Module
    Hi everyone
    So I got the dreaded warning lights come flashing up. So went to mechanic and I need a new ABS module.
    The thing is he said just the part is $1000 and must be done by VW dealership.
    Does this sound right??
    Also to try and stop the constant flashing warning lights I was stuffing around with my fuses now the airbag
    warning light wont go away!!
    Need Help!!
    Thanks in advance!!
    Airbag needs to be reset with VCDS. You can't pull fuses randomly without having one on hand.
    I would be looking for an independent VW specialist to check the ABS out.
