So the trunk light is woeful, seriously a single 5 watt bulb to light the whole trunk, what where they smoking ?
I purchased some cheap ebay LED strips for another project and had some extra.
I have used a 50cm strip. 36 x 7020 SMD LED, 9 watts. You could use a lot lower spec strip and still get good results.
10X 50cm 5630SMD Cool White Rigid LED Light BAR AL Case Milk Clear Cover CAP 12V | eBay
The strip light I have required some assembly.
The wire was only 10cm long so I soldered on a longer wire about 90cm, I used some speaker wire I had lying around.
Then I marked the polarity on the wires.
Added some double sided tape to the back of the light.
Mount the light in the boot. I chose to put it up high on the metal cross member section.
Route the wire behind the boot lining and around to the existing ****ty light.
Now to hook it up.
Remove the existing light, it just pulls out.
Remove the electrical connector.
There are probably heaps of better ways of doing this. Splicing / cutting & soldering / new connectors etc.
I choose to simply strip back and expose a small amount of wire and push into the connector. Then tape it all up.
The brown wire with black stripe is the earth BTW.
Enjoy your newly lit boot.
The light seriously shines out your trunk now.
Total time was about 20 min including the soldering.
Now to hook it up.
