MkV GTI fans
  • MkV GTI fans
    There was a squeaking noise on my car recently and occured when starting the car and staying on idle. I changed the timing belt but its still there.
    Is it the radiator fans? I heard they are expensive to change?
    could be your pressure valve...try removing your oil filler cap with the engine running...if it doesnt come off your pcv valve is buggered...causes a sqeal noise running and will hiss for a while when you turn off the engine
    BRISBANE / GOLD COAST
      It can squeal after shut down, liken it to a balloon full of air being let out slowly. Only happens when the diaphragm just splits, when fully busted itll run bad anyway
      Alba European
