thanks for you help. will keep it as a last resort.
MK5 TDI rough start issue
Please keep us posted on your progress, i have had this problem for as long as i can remember, i am going to do my glow plugs then maybe look at cleaning the starter. Good luck
07 Jetta Tdi, DSG(tuned),Gtb1756vk turbo, 3inch dump, Malone tune, 4bar map, EGR+EGR Cooler delete, S3 Intercooler, Hard pipe kit, Gti rear sway bar, 18x8 Enkeii gtc01, nitto tyres, Rear Lip Spoiler, Votex Front Lip, Slotted and drilled rear Discs, Neuspeed springs, LED interior lights, Blackened window trims, Carbon covered pillars, Gti lower front Grill, canbus update, rcd510, tinted indicators, gti paddle shift wheel, soon to have Votex Side Skirts, Coilovers, Porsche Brakes,8mm wheel spacers, Alloy control arms, GTI front sway bar, S3 bushings....
I have a feeling it is related to the starter and diesel injection. Just a hunch as it does everything else perfectly. I think it is starving of fuel due to the low crank rpm of the starter which i have read is a common problem when it is worn down. I think it could also be related to the injectors, they may be dirty.Last edited by kaiisons; 16-02-2015, 07:49 AM.
Production Automotive on Batt St in Penrith - I take my Polo there to get serviced, they are VW specialists.Originally posted by kaiisons View PostI have a feeling it is related to the starter and diesel injection. Just a hunch as it does everything else perfectly. I think it is starving of fuel due to the low crank rpm of the starter which i have read is a common problem when it is worn down. I think it could also be related to the injectors, they may be dirty.I SellNissansSkodas.
IT'S HEREEEEE 18' Skoda Octavia 110tsi Manual Hatch | Race Blue | Tech Pack | Luxury Pack | Panoramic Roof | Turini Alloys | Various VCDS Tweaks | RS Spoiler | Mars Bar Holder
R.I.P; 13' VW Polo 77tsi Comfortline Manual | Candy White | Sport Pack | Pioneer AVH X3800DAB + Clarion Bass Pack
Have you actually checked the battery?? How old is your battery?? Your symptoms match perfectly with a battery on its way out. These diesels are very sensitive to voltage and put high load on the battery which shows a weak battery earlier. The combo of lower voltage + too slow crank speed = no start speed reached and Ecu prevents engine run.
No grommets in the cover itself?? If not that's why it rattles a lot :pOriginally posted by kaiisons View PostThanks Piper I will see if I can get the battery load tested as soon as possible. There is only one rubber grommet on mine where the 10mm nut is at the back of the engine. Hoping it is something simple as the battery
How did they test the battery?? Not saying they haven't done it right just I see it quite a lot where aftermarket/ generic battery testers say a battery is fine. Genuine / vas battery tester shows battery is worn or on the verge of wear.Originally posted by kaiisons View PostIt is not the battery, had it tested at a battery shop and they said it was still fine. Now the car is wobbling under hard acceleration. I think I may have bought someone elses problem.
Also what is the rating of your battery??
If you are concerned about starter motor then easily checked with a multimeter.
By wobble under acceleration what exactly do you mean. May have engine mounts wearing
