Hi all,
It's been a while since I posted here and I've done a search but haven't found what I'm looking for so here goes.
I've got a factory fitted tow bar with the 13 pin plug and adapter to 7 pin at delivery on 05. I've used it in the past and it all worked fine.
I know have a glider trailer fitted with LEDs and the lights on the trailer wouldn't work, all I had was some random pulsing on the side lights. The trailer lights work fine hooked up to another car and when tested.
When I tested the car with a multi meter and a light sauce I was getting weird indications that made no sense.
So I did as much reading as I could find and found on the Amarok page some info replacing the 13 pin plug with a 7 pin.
So I did the swap, I found that the 13 pin plug had an earth issue anyway. With the 7 pin plug installed I've got everything working but I have faint blinking through the lights that aren't in use. Also with the lights off and the key out of the ignition the taillights/blinkers flash every couple of seconds.
Does anyone know of a solution for the blinking/flashing with LEDs fitted to the trailer?
Phil
Phil
