Hi,
Hoping someone might have seen this before. So I went down south for work last week and after driving down with the car not missing a beat, I went to drive somewhere after stopping and the CEL was flashing and i had no acceleration. I have had this once before about a year but I cleared the light and it never came back, this time if I clear the light I can drive the car perfectly, idles perfectly, drives perfectly, no loss of power etc but once I stop and remove the key, if I put the key back in the light is flashing again. I have a stage 1 APR tune but am having trouble using the cruise control functions to do anything right now so I can't put the car back into stock mode to see if it makes a difference.
I took the car to the small VW dealership where I was and had them take a look and they had a fault code relating to the ignition switch. They ordered the bit, did the swap and the fault code went away but the flashing CEL stayed. As did the no acceleration. I didn't have much choice as I needed to head home so given there was 0 fault codes showing on their system and I knew the car drove perfectly I've now driven the two hour drive home but still need to get this issue sorted. I am trying to avoid taking it to the local VW as I don't want them to dig too deeply and find the tune. Has anyone had this issue before, could it be something wrong with the tune itself? It's been fine for over a year now. Have not rung APR yet but will be doing so tomorrow.
EDIT: Forgot car details. MK5 Golf GTI Pirelli. Stage 1 tune is the only mod.
