I have one of the earlier 2.0 TDi Comfortlines ie with the 103kW motors
I had always thought it did not have a Diesel Particulate Filter, mainly because I had noticed from day one that "diesel cloud" illuminated by car headlights in the rear view mirror when revving past about 3000rpm. I also reasoned that because there was no DPF (and hence more soot etc exiting the exhaust) the tailpipes from the rear muffler needed to be tucked under the rear apron of the car and directed downwards toward the road.
Anyway I was following a GT TDi the other day and as well as noticing the clean "soot free " twin chrome tailpipes I did not see any of the "diesel cloud" even when I was pretty sure the driver was giving it a bit of a hurry up accelerating away from a set of lights.
My question is whether the 125kW 2.0 TDi now has a DPF (and hence the reason it can get away with the chromed, rear facing tailpipes) or is it something about this 2.0 TDi motor that might explain it (ie higher compression ratio/bigger turbo = more efficient burning, less particulate matter)??
