Audi (VW) have just announced some new technology premiereing on the Q5.
http://www.thetorquereport.com/
Engines
"The 2.0 TFSI has been entirely redesigned. The four-cylinder engine unites three high-tech features - turbocharging, gasoline direct-injection technology and the innovative Audi valvelift system for variable control of valve lift.
The high torque of 350 Nm (258.15 lb-ft) is available at 1,500 rpm and remains constant up to 4,200 rpm, with performance peaking at 155 kW (211 hp). The Audi Q5 2.0 TFSI sprints from 0 to 100 km/h (62.14 mph) in 7.2 seconds, reaching a top speed of 222 km/h (137.94 mph). On average, the vehicle consumes just 8.5 liters of fuel per 100 km (27.67 mpg)."
Transmissions
"Audi has built innovative technology into both the 3.0 TDI and 2.0 TFSI - the S tronic, a new twin-clutch transmission with seven speeds. This high-tech component can execute gearshifts in just a fraction of a second while offering exceptional comfort and high efficiency. Drivers can let the seven-speed S tronic shift automatically or select gears manually, when desired with rocker switches on the steering wheel."
If you look at the specs you'll notice the 3.0 TDI (Common Rail) makes 500 Nm, and the recently released 7 gear dry DSG is only rated for 250 Nm. The existing 6 speed DSG is rated for 350 Nm, so this new 7 speeder is a beast, and brings DSG to a long array of models that were previously too torquey.
Engines
Transmissions
