Fusebox B terminal part number/repair wire
In the remarks section of etka the numerals 1.5 means the wire Gauge scroll down I think 1.0 is most common but depends on what's being installed. The part numbers will give you gold or silver choices.
Look for T40/20 in the diagram! this is what I guess you need to find the terminal for the aux heater
The 1.5 means the wire gauge and the RO/GE is the color.
Problem is Etka will not give you a picture of the required terminal it only gives you an option of all the terminals that will fit the E-box, You need to know what the terminal looks like then make your correct option. My advise would be to remove terminal T40/25 see if it fits T40/20 as they look identical,if it does then you know what it looks like,then going from pictures on etka order the right terminal. I would be sticking with 1.5 gauge as described in the electrical wiring diagram.
OKay this i understand, but why etka has two numbers in remarks. - Like for 151E, it has 1,0 and 2,8.
When looking at terminals only ones that have 1.5, don't even look similar to t40/20, they look more for t40/28 and so.MY2007 VW MKV TDI 4Motion - 4motion snow fun machine
MY2018 SEAT LEON MK3 FR 1.8TSI - When You can't afford Cupra
Figured it out
No mather if is international or something else.
First number is wire crosssection etc 2.5, other number is terminal size 2.8.
I bought a half made webasto harness from a local vw guy. He has made the power part of the harness with 1.5 wire.
And reading from internet 1.5 til 2.5 use same terminals.
Also bought these from internet, if they arrive i can check if they fit.
Audi VW Skoda Seat Set of 6 Crimp Terminals Pins for Repair Wire 000979242E | eBay
These are too small for 1.5 wire.
Audi VW Skoda Seat Set of 6 Crimp Terminals Pins for Repair Wire 000979151E | eBayMY2007 VW MKV TDI 4Motion - 4motion snow fun machine
Words of progress.
Bought every need detail for install(including climatronic from mk6 and alot of other stuff).
You can see some bits from this pic. Including hoses, new washer tank etc... .
But when installing i ran into trouble. The Pipes wouldn't fit because of their shape, washer fluid pump hoses and wiring has to be customized and so on.
Unfortunately i didn't have needed parts at the moment and layed it all back together. I already asked local vw guy to do install, cause i don't have another 10h to spend doing it.MY2007 VW MKV TDI 4Motion - 4motion snow fun machine
