Hey guys I recently fitted an intake to my mk5 gti and it now the spool and bov is extremley loud, its like its amplified in the cabin. Is there some sort of noise pipe on the adm models? I also have a wrx with a td06 and no air filter and the gti spool is alot louder
fitted intake now really loud
What intake and can you do us a photo?Originally posted by davey_charlie View PostHey guys I recently fitted an intake to my mk5 gti and it now the spool and bov is extremley loud, its like its amplified in the cabin. Is there some sort of noise pipe on the adm models? I also have a wrx with a td06 and no air filter and the gti spool is alot louder
Never seen a review on that one mate.Originally posted by davey_charlie View PostSpyder intake with k&n filter
Just wondering if as an experiment you could fit something around the filter. This won't sound right but I know what is in my head
If you had a suitable coffee tin cut so it would sit over the filter and be sealed to at the bottom. Probably with say at least an inch clearance from the filter at all points.
I wonder if that would quieten it down. I know it's a bit of work but as an experiment, I wouldn't spend too long on it. If it cuts the noise then I'd look at making something more permanent and aesthetic.
I think open filters tend to allow the sound to bounce around in the enclosure too much.
More thinking out loud. You could also try some sound deadening material on the shielding. Like the wadding they use in speaker boxes or dynamat. Again for experimental purposes before a permanent fix.Last edited by h100vw; 06-04-2014, 12:13 PM.
Ill second that. OE intake is probably more than sufficient for a standard or mildly modded motor.Originally posted by Tom87 View PostIf you didn't get any performance gain, just put the old intake back in and put the aftermarket one up for sale.
Nothing worse than driving a vacuum cleaner.
Years ago I should of got into the Air Intake game, many a sucker around the corner
Prev 2008 R32 3 door DSG.
Now Lexus IS350 F Sport
