I had an accident with my 08 golf gti and front lower lhs was damaged. As the wheel was pushed towards the door at the time of the accident i replaced lhs lower contol arm and steering rack (steering rack was replaced because inner rod was bent and that damaged the rack itself) and that seemed to have fixed the problem..After these parts were replaced and i tried to turn steering to full left lock, the lhs tyre hit lower arm slightly before full lock was completed. It feels like my steering rack was positioned more to the right when it was installed. Can steering rack be adjusted left or right or should I be looking at other possible problems? Thanks
Golf Gti Steering Problem
Sounds as though there is more damaged components on the LHF of the car than you thought. Have you had a proper wheel alignment done since, and if so what were the readings for things like camber/caster/toe/toe out on turns etc?'77 Golf mk1 GLS - ground up resto - Sold
'97 Golf mk3 GL Wolfsburg Edition - JOMs, daily driver - Sold
MY17 Golf GTI 40 Years Edition - DSG
2010 GSX-R 750 - Daily rider
Sounds like the rack isn't centred.
Loosen the jam nuts on the tie rods, get a permenant marker, and draw a line along the tie rod end, and then onto the tie rod. Do this both sides.
Now, turn the left side one anti-clockwise a full turn, so that you're exposing more thread (i.e. lengthening the tie rod). Turn the right side one clockwise to shorten it the same amount.
See how it goes from there.'07 Transporter 1.9 TDI
Cannot be close at all..lhs i have to unscrew it as far as possible (expose almost full thread) and on the rhs i have to screw it in to the end (expose only little bit of thread because tie end cant go any further inside) and the wheels are still not straight perfectly...they need a bit more.
Climb under your neighbour's one and measure the amount of thread you can see at both sides, and do the same for yours.
THEN go get a wheel alignment.
Basically, you've chased your tail trying to get the wheels straight, that the rack is miles off centre.'07 Transporter 1.9 TDI
