MK5 Jetta - Emissions Garage ?!?! EGR ?
  • MK5 Jetta - Emissions Garage ?!?! EGR ?
    Hi Guys
    My 2006 MK5 Jetta TDI threw up this at me last night. Emissions Garage with the CEL on.
    After looking into it seems like its a EGR issue, stuck flap etc.
    I can see there is a lot on it but basically I don't want to read through multiple pages and hopefully someone can give me a direct and quick answer on how to fix it.
    My car has 170,000kms
    Can it be removed and cleaned?
    Do I need a new one?
    Would a second hand one suffice?
    Do I need to take it to a specialist?
    Am pretty mechanically minded so removing it wouldn't be an issue.
    Any help advise would be appreciated.
    Thanks Brad
    Can be cleaned (irritating job but not overly difficult)
    Could need a replacement if the flap isn't just blocked by the build up of soot and grime (extremely common build up)
    You want need to take it to a specialist.
    The problem will most likely be that the build up has just blocked the flap from moving freely, so simply remove, clean the a bare finish (as detailed as possible, will take a while but just keep at it with rags, toothbrush or form small brush and carby/inlet cleaner)
    Then clear the code with a vagcom cable (if you don't have one someone will help you out for a few beers usually. If you in Melbourne I don't mind clearing it for you.)
    Then if the problem is still there the flap must be f***ed I'd say...
    Hennessy Auto Styling MK5 TDI [SIZE=3]|| United Grey || Sunroof & Leather || 18x8.5 +45 Rotiform BLQ and 17x8 17x9 +39 Stern Reverse Face II || K Sport Deluxe Air Suspension || After Market OEM Style Body Kit and Accessories!
    Hennessy Auto Styling - Bumpers, Spoilers, Carbon, Lips and more.
      Thanks lhennessy will take it off this weekend and give her a clean up. Cheers!!
        Plus it usually blows the fuse in the fuse box by the battery when the flap blocks.
        If it's very blocked, it buggers the plastic gear that controls the flap.
