Battery drain issue
  • Battery drain issue
    Hi,
    Hoping someone can help.
    I have a 2006 Jetta 2.0T. I upgraded the radio to an RCD510 bought from a forum member a couple of years ago. I also upgraded the can bus gateway with one from an '08 model. Everything worked and life was good.
    I have recently replaced the battery. I can't recall if it was before or after that I first heard it, but when the car was unlocked there was a 'ding' sound coming through the speakers which was a new warning sound I hadn't heard before. I have since realised prior to unlocking that this sound is also coming through the speakers with the car switched off and locked. Obviously this is draining the battery in 2-3 days.
    I just removed the battery and charged it. I measured the battery drain when reinstalling and it is around 15-20 mA. Note, I have not heard the ding sound since reinstalling the battery tonight.
    Does anyone have any ideas what could be causing the battery drain or have heard a ding sound through the speakers with the car switched off? What is the battery drain that is expected?
    Dan
    Blinker left on I bet. Mine doe that, and it's a ding.
      With ignition off and either indicator left on it puts the park light on for that side and warns you via the beeping .....VDUB....
      BRISBANE / GOLD COAST
        The 15-20mA is normal current draw after few minutes when you lock your car. Such a small current will not discharge your battery, unless you read the voltmeter wrong and the current is 200mA or 2A.
        Performance Tunes from $850
        Wrecking RS OCTAVIA 2 Link
          Nope, not that sound!
            Thanks Transporter. The noise, and the battery drain seem to have mysteriously disappeared. Experience tells me it'll be back... and if it does come back I will re-check the current draw then
