EDIT:
Car is GTI 2006 DSG with 85k on the clock.
I had been noticing on occasion the car would rev itself in idle and sound a little rough. Everyday driving was otherwise fine, seemed normal. Engine light came on a day or so after, so I took it in to get looked at. All codes were cleared and I drove back to get it checked again.
These were the errors thrown back:
Leak in Air Intake System P2279
Lower Limit Reached
Bank 1; System too Lean at Idle
P2187 No Signal/No Communication
Idle Control System RPM Higher than Expected.
P0507 Upper Limit Reached Intermittent
I did a bit of research into it myself and it all seemed to suggest a vacuum leak and possible need for a new PCV valve. I pulled the oil dipstick with the engine running and there was definitely suction and the engine was rough with it out.
Anyhow, after a day at the workshop I was told that it's no issue with valves or the like but broken piston rings causing the issue. I was shown some pressure gauge hooked up which indicated little pressure from the cylinders. Was told that either I'd need to replace the engine with another or get the current one reconditioned - both which will cost a fortune.
Has anyone else had this problem and should I get a second opinion (that alone will cost a lot)? Looking for some advice from those who have had experience with this sort of thing before.
Lower Limit Reached
