MKV R32 Xenons didn't "pop back up"
  • MKV R32 Xenons didn't "pop back up"
    Gday all,
    My wifey's R32 xenons didn't 'pop back up' a couple of nights ago upon startup. When the car turns on, it usually does this point down then point back up sequence as part of the self levelling function.
    I do have a VAGCOM cable but I thought, look, it's under warrantly, let's see what the boys at VW say.
    So the wifey brings the car in and they blame it on the DRL lights I installed well over a year ago. Bear in mind that I installed the DRLs into a spare circuit which had nothing to do with headlights. They unplugged my DRLs and yes the Xenons worked again......but.....
    Low and behold......the lights didn't point back up again tonight and the DRLs aren't plugged in.
    I'll plug in the VAGCOM tomorrow but just wondering if anyone's had this issue before? I read up on another site overseas it may be the servo motor?
    Cheers.
    MKV R32 Xenons didn't &quot;pop back up&quot;
    Use the cable to scan for errors. Should always do that before approaching a dealer.
    They will use most things to get out of doing warranty repairs, but it does sound like the DRL's caused an issue to begin with. Could be the auto leveling system though.
    Sent from my eyePhone in the year 3013.
      It will be a fault anywhere in the xenon system...as a default if there is a error it puts them to the lowest setting so it does not go too high and blind oncoming drivers.....VCDS scan will show either a level sensor issue or control unit data error....VDUB...
      BRISBANE / GOLD COAST
        Thanks guys. I'll do the scan.
        The latest is they are trying to blame the drls causing a short..................but the thing is, they work again intermittently so I would have thought if the DRLs stuff up the system in any way, they wouldn't work all the time, not just once in a while?
          Ok, have some good news, they didn't clear the codes when the car was brought in as when I just did the scan, there was a once off error for something else 4000kms ago.
          Um, may be a funny question but would VW be in a position to say that I shouldn't be using a VAGCOM cable and any issue could have been caused by me and void warranty?
          I took a video showing the lights currently do pop down and up again (therefore showing they do work sometimes and providing the argument that if my DRLs caused them to fail, why would it still work).
          Here are the errors in scan (first one seems to be climatronic related and the one at the bottom alarm related?):
          Address 08: Auto HVAC Labels: 1K0-907-044.lbl
          Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
          Component: ClimatronicPQ35 120 1111
          Revision: 00120021 Serial number: 00000000000000
          Shop #: WSC 00000 000 00000
          VCID: 79D72376303751D0
          1 Fault Found:
          00716 - Air recirculation Flap Positioning Motor (V113)
          000 - - - Intermittent
          Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
          Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
          Component: Bordnetz-SG H54 2202
          Revision: 00H54000 Serial number: 01000007590
          Coding: E68F8F2700041500471400001400000000097B075C00010000 0000000000
          Shop #: WSC 01287 785 00200
          VCID: 71C71B5668471990
          Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB
          Component: Wischer 060102 021 0501
          Coding: 00038805
          Shop #: WSC 012
          Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB
          Component: RLS 051007 046 0204
          Coding: 00207646
          Shop #: WSC 01287
          1 Fault Found:
          02499 - Right Low Beam Reflector Motor (V295)
          012 - Electrical Fault in Circuit - Intermittent
          Freeze Frame:
          Fault Status: 00111100
          Fault Priority: 3
          Fault Frequency: 1
          Reset counter: 108
          Mileage: 66211 km
          Time Indication: 0
          Date: 2005.09.13
          Time: 31:63:63
          Freeze Frame:
          ON
          Voltage: 11.55 V
          ON
          ON
          OFF
          OFF
          OFF
          Address 55: Xenon Range Labels: 1T0-907-357.lbl
          Part No: 1T0 907 357
          Component: Dynamische LWR 0003
          Coding: 0000004
          Shop #: WSC 01279 785 00200
          VCID: F4C992429755ACB
          1 Fault Found:
          01534 - Control Circuit for Left Headlight Range Adjusting Motor (V4
          010 - Open or Short to Plus - Intermittent
          The following is interesting, just the alarm going off? Seems like it's only happened once 2000kms ago?
          Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
          Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
          Component: KSG PQ35 G2 020 0204
          Revision: 00020000 Serial number: 00000000000000
          Coding: 819002005103087F2D048C0D70085FC610FC00
          VCID: 832BC19EC2FB9B00
          Part No: 1K0 951 605 D
          Component: LIN BACKUP HORN H07 9001
          Part No: 1K0 951 178 A
          Component: Neigungssensor 003 0203
          Component: Innenraumueberw.003 0203
          3 Faults Found:
          01135 - Interior Monitoring Sensors
          004 - No Signal/Communication - Intermittent
          Freeze Frame:
          Fault Status: 00100100
          Fault Priority: 4
          Fault Frequency: 1
          Reset counter: 73
          Time Indication: 0
          00323 - Vehicle Inclination Sensor (G384)
          Freeze Frame:
          Fault Priority: 4
          Fault Frequency: 1
          Reset counter: 73
          Mileage: 64850 km (2000 kms ago)
          Time Indication: 0
          Date: 2000.00.00
          Time: 17:44:11
          01134 - Alarm Horn (H12)
          Freeze Frame:
          Fault Priority: 4
          Fault Frequency: 1
          Reset counter: 73
          Time Indication: 0
          Date: 2000.00.00
          Time: 17:44:11
            Save vcdc codes
            Clear VCDS codes
            Unplug both headlight harness and plug back in. Reseat the terminals.
            Test
            May also want to look at LHS rear wheel leveling sensor and if there is a connector unplug it then plug it back in.
            Sound stupid, but sometimes it just the connection needing pulling apart and back together a few times just the clean the terminals.
            \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
            ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
              Thanks Gigitt for the advice.
              As the car is still a number of months away from having it's extended warranty expiring, I'll see what the dealer will do first (and avoid excuses not to cover it under warranty).
