Hi All,
I have an 2006 GTI, APR Stage 2+ tune. Dump and full APR exhaust. For the last 3 months I have the below error codes.
Fault codes.
012600 - Intake Manifold Runner Control
P3138 - 008 - Regulation Deviation
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 76823 km
Time Indication: 0
Date: 2000.00.00
Time: 11:13:23
Freeze Frame:
RPM: 3626 /min
Load: 18.0 %
Speed: 92.0 km/h
Temperature: 83.0°C
Temperature: 18.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
008200 - Intake Manifold Flap; Bank 1
P2008 - 001 - Electrical Malfunction
Freeze Frame:
Fault Status: 01100001
Fault Priority: 0
Fault Frequency: 1
Mileage: 76823 km
Time Indication: 0
Date: 2000.00.00
Time: 11:13:23
Freeze Frame:
RPM: 3500 /min
Load: 28.2 %
Speed: 92.0 km/h
Temperature: 83.0°C
Temperature: 18.0°C
Voltage: 14.224 V
Have done Basic settings with VCDS out put tests, unplugged the motor and replugged etc. All run OK. I can see the Intake Manifold motor moving.
Service place said the intake manifold motor is not moving wile the car is driving. It can't work out a fuel base line and one is not set.
My low end performance has declined and fuel usage is down 150 - 250mk a tank.
I think i really have 3 options.
1) APR Intake Manifold delete kit. with labor about $800 - $1000
Can't find any reviews on the kit and if fuel usage would be better or worse then stock. At least with the kit the problem would be gone to never return.
2) Get the service place to look closer into the problem. 120 + an hour labor. And then new parts ect to replace maybe manifold and motor. ($400 - $1000+)
3) Get a new Intake Manifold motor with the same part number have them fit it and run basic settings. Hope it works. About $200 for the part labor on top of that. May not fix the problem.
Any one have some wisdom / had this happen to them or any one with the APR delete kit.
Fault codes.
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 76823 km
Time Indication: 0
Date: 2000.00.00
Time: 11:13:23
Freeze Frame:
RPM: 3626 /min
Load: 18.0 %
Speed: 92.0 km/h
Temperature: 83.0°C
Temperature: 18.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Mileage: 76823 km
Time Indication: 0
Date: 2000.00.00
Time: 11:13:23
Freeze Frame:
RPM: 3500 /min
Load: 28.2 %
Speed: 92.0 km/h
Temperature: 83.0°C
Temperature: 18.0°C
Voltage: 14.224 V
