hey all, just a quick question, would the GTI suspension(stock) go straight into a TDI?? if not would just the springs work with the stock TDI shocks??
p.s. MY08 2.0TDI comfortline, if that makes a difference
cheers
Jonasz
Mine: -MK5 Golf 2.0TDI[Deiselgeek sigma 6 shifter + H&R 50mm lowering springs + GTI Tartan interior + Audi 18x8 A6 wheels(Dark Steel)]
-MK1 Golf The re-spray/re-build
In the family: -MK5 Jetta 2.0TDI, -9N3 Polo TDI, -6R Polo TDI, -Mitsubishi S^$&box van
A pattern seems to be forming...
Have heard its been done before but but I would be concerned - there's quite a weight difference between the diesel engine in the TDI and the petrol engine in the GTI - there's a reason why they make specific TDI springs/suspension.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
It will work but you'll have a bit more drop in the nose. You would want the dampers to be reasonably fresh - 40,000km tops or buy some new ones (sachs are pretty cheap).
Don't forget the swaybars - do at least the rear. The front is a pain.
I also wouldn't bother if you are paying labour to do the job.
Mk6 gear fits as well.
What are you trying to gain by doing the swap? Lower ride height or better handling?
Personally, I went the other way. I have a 118tsi petrol Skoda Octavia hatch & fitted Octavia vRS diesel wagon Eibach springs & Koni Sport adjustable dampers. Turned out fantastic! (Octavia has the same suspension as a Golf)
carandimage The place where Off-Topic is On-Topic I used to think I was anal-retentive until I started getting involved in car forums
Well its my daily, so i was hoping to gain a slight bit of performance, and tiny bit of a height drop. But from what your saying, it would be better to get some new springs and shocks to do that. was considering getting some coilovers, but the car gets driven ALOT and adelaide roads are like swiss cheese.
Might look into some stiffer springs in the future, cheers lads.
Quality coilovers won't necessarily ruin your ride quality.
Research, research, research!
I would rate the Koni Sport dampers as the 2nd best mod I've done to improve the vehicle. #1 was a remap.
BTW: there are some KW V1 in the for sale area. They are supposed to be decent quality.
Thats the thing, i cant afford good quality coilovers, which is why I would prefer to go for something a bit tamer, unfortunately 6 years of uni and being a masters student has stripped me of all my money, and time to make moneys, so anything i do has to be on the cheap.
thanks anyways
brad is using the correct terminology which may be confusing you as almost everyone else here speaks Americano when discussing suspension (hey, check out my sways, dude).
Dampers are exactly that - the units that dampen (ie control) the response of the vehicle and wheels against the springs (which are shock absorbers when you think about it).
So brad is proposing that you replace just the damping units to get better vehicle control without sacrificing any ground clearance or much comfort. It isn't popular here as there is no visual aspect but it is a much bigger performance enhancement than just lowering springs (which I would argue are actually detrimental to real performance). Unfortunately, decent dampers are not much cheaper than a decent cup kit (lowering springs + matched dampers) so once you factor in labour, there isn't much cost savings over a cup kit, although you could just fit the dampers and sell the springs as a lowering kit
Resident grumpy old fart VW - Metallic Paint, Radial Tyres, Laminated Windscreen, Electric Windows, VW Alloy Wheels, Variable Geometry Exhaust Driven Supercharger, Direct Unit Fuel Injection, Adiabatic Ignition, MacPherson Struts front, Torsion Beam rear, Coil Springs, Hydraulic Dampers, Front Anti-Roll Bar, Disc Brakes, Bosch ECU, ABS
