Hi Maelgwn,
I have had time to have a quick look into it. The fault code was coming up in the central electrics control module as well as the back door modules. It was odd that the remotes would unlock the doors but not lock them and the Lock/ Unlock on the drivers door would work them fine.
The fault code looks like it could be related from anything that talks on the CAN network as well as a damaged wire, as you know that the doors work I think it would unlikely be a wire. I'm leaning more towards the Central electrics module.
I haven't pulled one apart (Yet) so I'm not 100% sure on how it works but I'm thinking that the rear doors would work as one output, I think that it would be this which is not working. It could be from either a damaged component on the PCB, corrosion or dry solders, I have found the dry solders to be common in VAG cars so this is where I would be starting.
One way that you can try narrow this down is to unplug the CECM from the CAN and see if the fault goes away.
