Hi,
I have a 2006 golf r32 (112,00kms) and its been making a clunking noise for the past month or so. Its more noticable inside the car than outside. It seems to happen when I first turn on the car and reverse out of my drive way and when i make a turn it gets louder. it is even now when I drive straight (you can slightly hear the noise). I first thought it may have something to do with the steering but since I can hear it when I drive straight, I don't think so anymore. I know I need to change my break pads and rotor disc soon, so I don't know if this may be the cause? I was also told that i would need to change my bushings but the mechanic said i could wait until i hit 115,000kms. Before it used to only happen within the first 10mins or so driving, but now even after doing a 20min+ trip I can still hear it. Has anyone else had this problem? Can anyone recommend a mechanic that would know what this may be? I don't have a lot of money to throw at mechanics that wouldn't have a slight clue about it. I'm located in the south western Sydney area.
Thanks in advance!!
Solution found!!!
Strut bearings Left side – That is the cause of the noise at the front of the car.
All thanks to:
Jack Miaskowski
jack@beyondlimitautos.com.au
PH 61 88542080
M +61 409655027
Thanks in advance!!
Solution found!!!
All thanks to:
Jack Miaskowski
PH 61 88542080
M +61 409655027
