A/C stopped working - VAG code help
  • A/C stopped working - VAG code help
    My A/C stopped working the other day.
    It was working fine and was super cold before it stopped working.
    Then all of a sudden one day it just decided to blow out warm air.
    Almost died in the heat yesterday..
    Ran the VAG scanner and found the following error code.
    Is it just as simple as getting the refrigerant topped up?
    I have read in other forums the A/C's in MK5s are a problem.
    Anyone have any experience here?
    Hope it is not another expensive fix
    Address 08: Auto HVAC Labels: 1K0-907-044.lbl
    Part No SW: 1K0 907 044 BH HW: 1K0 907 044 BH
    Component: ClimatronicPQ35 090 0909
    Revision: 00090016 Serial number: 00000000000000
    Shop #: WSC 00000 000 00000
    1 Fault Found:
    00229 - Refrigerant Pressure
    002 - Lower Limit Exceeded
    1 Fault Found:
    The code is basically saying you are low on refridgerant. Get it checked out, find the leak and recharge the system.
      This is where everyone gets caught out with this fault code
      The compressor is buggered and cant build up enough pressure to run the system properly . Its not really common for mk5 Golfs to lose gas , it is common for them to have compressors wear out !
        I am getting the same code with my AC and I had a refrigeration mechanic/sparky look at it before I take it to VW (on Monday). He claims there's no issue with the compressor, just my resistor in the blower fan is having an issue. It could be the same issue for Mini, but I had a look around and everyone is claiming it's low on refrigerant.
        I'd bite the bullet and take it to VW.
          They'll lose gas if it leaks out the pressure sensor, as it commonly does.
            Hi deadpool, let me know how you go.
            I have searched a few other forums who suggested it could be a few things.
            Fuse, relay, fans, compressor etc.
            I have checked fuses and they are all good.
            I am hoping it is a relay or something small and not the entire compressor.
            Anyways, will take it to an ex-VW mechanic next weekend also.
              My GTI will be in at Barloworld on Monday. I'll give you an update sometime in the afternoon when they've diagnosed/fixed the problem.
              Stay Tuned!
                1 Fault Found:
                AC compressor and TX value were dead.
                Now replaced and working again after lots and lots of $$$.. sigh.
                  Damn man! Glad to hear it's sorted, sad to hear that it cost a lot.
