Different air con. and fan blower problem
  • Different air con. and fan blower problem
    Hi,
    I have a bit of a different problem with my air con in my 2007 MKV GTI. As follows:-
    - Air conditioning is working OK except after about 1 hours driving the fan blower air reduces down, even when I adjust the climate controller down to low temp and turn up fan speed.
    -When I turn the fan blower speed on high the blower appears to be working within the dash (you can here the blower getting louder as the fan speed is turned up), however no forced air is coming out of the vents
    - The only way I can power up the fan blower and air con again is by turning off the air con completely. The longer I leave it off the longer it seems to stay on, before the the fan blower dies down again.
    - Can still feel cold air (slightly) at the vents during this time
    This is a pain when travelling long distances and when temperature outside is 27 - 40
    Any ideas on what the problem may be ? Seems to be a air temp sensor that may be getting cold and turning down the air conditioning fan speed (hence why it works again once it has been turned off completely for a while). Does anyone know where the internal cabin temperature sensors are located in the MKV?
    Mike
