Hi Folks,
Had my Jetta since 2008 (new) which had dealer fitted iPod cable through glove box. Last week I unpluged the iPod to connect to iTunes and change some playlists. I may have disconnected befor changing Head unit to a radio band from CD mode.
Since reconnecting the head unit says "NO CD" when I press CD mode (even multiple times). I have reset the iPod. I believe the head unit RCD300 is the issue as it will not play from my iPhone either (which it has in the past).
I called the dealer the advised against disconnecting the battery as it would set of a lot of warning lights apparently. They said the RCD300 would need resetting.
Is it possible to reset at home ? Any other solutions ? I've considered may be removing the fuse and replacing ?
