Hey can anyone help, put my gti pirelli up on the hoist for a routine check and took off the hose that goes to the intercooler and found little bit of oil but it was greyish in colour...its like metal fillings ???? is that the k04 failing , i've got 49000 km on the car,and seems to still have boost.......not sure.......anyone has had a similar issue
ko4
You always get some residue floating around the pipes. If it runs out of the pipe, then you should be concerned. Otherwise don't worry about it.Originally posted by solo72 View PostHey can anyone help, put my gti pirelli up on the hoist for a routine check and took off the hose that goes to the intercooler and found little bit of oil but it was greyish in colour...its like metal fillings ???? is that the k04 failing , i've got 49000 km on the car,and seems to still have boost.......not sure.......anyone has had a similar issue
Thanks Gavin , what do you mean when it runs out of the pipe . When the hose was removed from the inter cooler I run my finger inside it the hose and that's where it is that greyish residue is. Only on the hose where the left wheel is the other side of the intercooler there was nothing .. Peter
I mean if it pours out of the pipe work. There's always some oil mist in the intake.Originally posted by solo72 View PostThanks Gavin , what do you mean when it runs out of the pipe . When the hose was removed from the inter cooler I run my finger inside it the hose and that's where it is that greyish residue is. Only on the hose where the left wheel is the other side of the intercooler there was nothing .. Peter
