Hi All
My wife has a 2005 VW Golf 1.6L Comfortline with 6 Speed sports Automatic
It is a great little car however the transmission has started to play up and is terrible in traffic.
It has done 140,000 km and the transmission has started playing up to the point it will not drive reliably for more than 20 minutes or so. When it is cold it is ok, and gets worse to the point that it is shunting into gears both accelerating and slowing down.
We took it to a transmission repairer and they advised that it would cost between $5,000 to $6,000 and said it was quite bad and not just the valve body.
Just wondering if anyone has had there transmission replaced and who they went to ? and how much it cost?
Also if there is any other options to get it repaired, maybe another transmission from earlier or later golf? Either manual or auto?
The other question I have is if we get it repaired, how do we know if the same thing will happen, are they fixing the actual problem or just putting the same transmission back in??
The more I read the more I find that this was a VW problem and in other coutries there were recalls etc
Appreciate any help that you guys might be able to provide, we are not sure what to do as the car is probably worth around $10,000 (if the transmission was working). Maybe we should try to sell with the damaage for $5,000 or something like that?
Any thoughts?
Any thoughts?
