Help with direction on putting headlights in.
Hey jessv3 well this was my first real dyi that involved taking anything bigger than interior trim off... And I found it ok as long as you take you time and don't rush, do research and double check everything then you will usually be ok.
As for the 2 left over if you check the underside of the bumper there are screws all the way round and the 3rd one from each corner (so around either side of the Center grille) it is 2 screws in each section maybe that's where they are from? Could you put a picture of what screws they are? There should be 5 in each wheel arch (one is upside Down and the one that holds the most weight from the bumper)
Lemme know if that helps (if you can upload pics I can go have a look at mine and note each place for that sort of screw.
