mk5 gt tsi problem
  • mk5 gt tsi problem
    hi guys im i have a bit of a problem with my golf, the check engine light has come on and after driving for a bit i cant rev it over 3000rpm but anything under that is fine then if i restart the car its fine again for a while, any help would be great thanks
    You really need to have your car scanned for fault codes.
    MY20 Golf GTI TCR
    MY20.5 LR Defender P400 HSE
      yeah i think ill have to do that, but maybe someone has had this problem. its just strange that it goes away when i restart
        Your car has gone into limp mode that's why you can't rev it over 3000rpm, also why it's goes away after you restart it. When an engine fault is detected by the ECU, it's goes into limp mode to protect the engine. After you restart it it's fine until, the ecu detects the fault, just get it scanned by Vagcom or take it to the dealer.
          Originally posted by mk5fsi View Post
          Your car has gone into limp mode that's why you can't rev it over 3000rpm, also why it's goes away after you restart it until it. When an engine fault is detected by the ECU, it's goes into limp mode to protect the engine. After you restart it it's fine until, the ecu detects the fault, just get it scanned by Vagcom or take it to the dealer.
          thanks heaps
