2006 Jetta - Head unit power issue
  • 2006 Jetta - Head unit power issue
    Hi all,
    I'm hoping some one can provide some insight on a strange power issue I'm having with my head unit. The head unit I have is a Dynavin DVN-VW1, installed on a 2006 Jetta FSI Turbo.
    The issue is that when I start the car the head unit remains off and I have to turn it on manually.
    But if I start the car by turning the key to the accessory position for a few seconds first the head unit turns on automatically and stays on once the engine is running.
    It has got me baffled, any ideas?
    Thanks,
    Tom
    Anyone?
    I know the vw head units have a power drain issue with the early jetta's due to gateway, could it be the can gateway?
    clutching at straws here.
      Originally posted by TommyP View Post
      Hi all,
      Thanks,
      Tom
      Maybe the head unit has a relay of some sort in it and the brief contact passing through the accessory position doesn't activate it in long enough for the radio to start?
      A check on how it's wired to the ignition circuit might solve the problem.
        I spoke to the distributor and he is going to send out a replacement unit, hopefully that will fix the problem.
          If that doesn't solve it, a new contact switch on the back of the ignition barrel might.
