Looking at a used Mk5 GTI which has done 50,000kms. What will the DSG service cost so that I can factor this into the negotiations?
DSG oli/filter service cost
Try Golfwagen in Wangara http://www.golfwagen.com.au/index.php(though I think they've changed their trading name) or Quattro motors in Burswood, they're 2 independent VW service centres which are very good.
fwiw we had a our Jetta's DSG serviced at John Hughes a few years ago and they did a good job, no issues though was pricey, about what was quoted above.
Good luck
ChrisWLF127
Yep it's in there along with a long list of other 'checks' and 'replacements' they do. From memory one of the dealers broke down the costs for me and if I remember correctly the DSG alone was around $500. The only other VW servicing garage that I know of as shakespear mentioned is Quattro Motors. There's bugger all in Perth (that I could find) which make me sad
Originally posted by Umai Naa!! View PostBefore going to an independant, make sure they can actually do the job.MY09 Golf Candy White 2.0 TDI Pacific
MY95 Golf III TDI
Originally posted by Umai Naa!! View PostJust because it's working doesn't mean maintainance isn't required.
JmacAlba European
Originally posted by Mr Messy View PostMy DSG was done at 60ks by previous owner, then the 120k rolled around and I took it to Camden GTI. The DSG works brilliantly and we agreed to leave it alone as some DSG boxes had trouble with mechatronic etc post service.
The engine was running fine so no need to change the engine oil and filter.
The engine was running fine so no need change the cambelt.
The brakes were working fine so no need to replace the pads.
It's called preventive maintenance for a reason.
George06 Jetta 2.0TFSI Killed by a Lexus!
14 EOS 2.0 TSI has arrived!
