MK5 GTI oil (2.0L turbo petrol) preference.
  • MK5 GTI oil (2.0L turbo petrol) preference.
    Hey guys couldnt find anything searching.
    Im gonna do the maiden oil change on the new GTI tomorrow. Just wondering what oil the dealers are using in these things? I tried ringing them today but their service dept was closed.
    I figured i may as well put the same as what they do in there.
    FOLLOW US ON FACEBOOK
    According to my invoices, my dealer (who shall remain nameless) have used Mobil Super S 10W40. As far as l'm concerned, this oil does not comply with the required VW specification 502 00. But, what can you do. That's what they use.
    Coincidentally, today, l had an unscheduled oil and filter change done at Audvolks in Clayton. They used Castrol Edge 0W40.
    Castrol say the following about Edge 0W40.
    "This is Castrol’s best , full synthetic, low viscosity technology. The exceptional characteristics of this free flowing oil reduces friction and delivers ultimate wear protection and optimum engine performance right from start-up."
    It does comply with VW spec 502 00.
      Hey Tim.
      Keep looking to find a few threads regarding the oil issue.
      From what I've read on this forum you need to be careful with the oil you use
      for the MK5.
      I'm sure someone will direct you shortly to the thread.
      Neil
        Hi Tim
        If you are looking in using Mobil here is a list
        Mobil Mobil 1 ESP Formula SAE 5W-30 50400/50700
        Mobil Mobil Special X SAE 5W-40 50200/50500
        Mobil Mobil Special XS SAE 0W-30 50200/50500
        Mobil Mobil Super M SAE 15W-40 50500
        Mobil Mobil Super M SAE 20W-50 50500
        Mobil Mobil Super M Diesel SAE 15W-40 50500
        Mobil Mobil Super XHP SAE 10W-40 50500
        Mobil Mobil Super XHP SAE 15W-40 50500
        Mobil Mobil Super XHP SAE 15W-50 50500
        Mobil Mobil Super XHP SAE 20W-50 50500
        Mobil Mobil Super XHP Diesel SAE 15W-40 50500
        Mobil Mobil Synt S Special V SAE 5W-40 50000/50500/50501
        Mobil Mobil Synt S Turbo Diesel SAE 5W-40 50200/50500
        Mobil Mobil Syst S SAE 5W-40 50200/50500
        Mobil Mobil Syst S Special V SAE 5W-40 50000/50500/50501
        Mobil Mobil Syst S ESP SAE 5W-30 50200/50500
        Mobil Mobil SHC Formula V SAE 5W-30 50400/50700
        Mobil Mobil Synt S SAE 5W-40 50200/50500
        Mobil Mobil SHC Formula LD SAE10W-30 50601/50600/50300
        Mobil Mobil Super XHP SAE20W-50 50500
        Mobil Mobil Super XHP Diesel SAE15W-40 50500
        Mobil Mobil Formula S SAE 10W-40 50500
        Mobil Mobil 1 SAE 0W-40 50200/50500
        Mobil Mobil 1 SAE 5W-40 50200/50500
        Mobil Mobil 1 SAE 5W-50 50500
        Mobil Motor Oil Plus SAE 10W-40 50500
        If you're thinking Castrol
        Castrol Castrol 505 01 SAE 5W-40 50200/50500/50501
        Castrol Castrol DCO Top Up SAE 0W-30 50301
        Castrol Castrol DCO TOPUP SAE 0W-30 50200/50500
        Castrol Castrol Edge SAE 0W-30 50200/50500
        Castrol Castrol Edge SAE 0W-40 50200/50500
        Castrol Castrol Edge SAE 5W-30 50400/50700
        Castrol Castrol Edge Sport SAE 0W-30 50200/50500
        Castrol Castrol Edge Turbo Diesel SAE 5W-40 50200/50500/50501
        Castrol Formula RS Road and Track SAE 5W-40 50200/50500
        Castrol Formula SLX Long Tec SAE 0W-30 50301
        Castrol Formula SLX LongTec SAE 0W-30 50200/50500
        Castrol Formula SLX LongTec Turbo Diesel SAE 0W-30 50200/50500
        Castrol Castrol Formula SLX Turbo Diesel SAE 0W-30 50200/50500
        Castrol Castrol Formula SLX Zero SAE 0W-30 50200/50500
        Castrol Castrol GTD 505 01 SAE 5W-40 50000/50500/50501
        Castrol Castrol GTD 505 01 Top Up SAE 5W-40 50200/50500/50501
        Castrol Castrol GTD Direct Injection SAE 5W-40 50200/50500
        Castrol Castrol GTX SAE 15W-50 50500
        Castrol Castrol GTX SAE 20W-50 50500
        Castrol Castrol GTX 2 SAE 15W-50 50500
        Castrol Castrol GTX 3 SAE 10W-40 50500
        Castrol Castrol GTX 3 SAE 15W-40 50500
        Castrol Castrol GTX 3 SAE 15W-50 50500
        Castrol Castrol GTX 3 Protection SAE 15W-40 50500
        Castrol Castrol GTX 3 Protection Plus SAE 10W-30 50500
        Castrol Castrol GTX 3 Protection Plus SAE 15W-50 50500
        Castrol Castrol GTX 5 SAE 5W-40 50200/50500
        Castrol Castrol GTX 7 Dynatec SAE 5W-40 50200/50500
        Castrol Castrol GTX 7 Dynatec Neu SAE 5W-40 50200/50500
        Castrol Castrol GTX Magnatec SAE 10W-40 50500
        Castrol Castrol GTX3 Lightec SAE 10W-40 50500
        Castrol Castrol Longlife 2 Top Up SAE 0W-30 50300/50600/50601
        Castrol Castrol Performance SAE 5W-40 50200/50500
        Castrol Castrol Protection SAE 15W-40 50500
        Castrol Castrol Protection SAE 20W-50 50500
        Castrol Castrol SLX Longlife II SAE 0W-30 50300/50600/50601
        Castrol Castrol SLX Longlife III SAE 5W-30 50400/50700
        Castrol Castrol SLX Turbo-Diesel SAE 0W-30 50200/50500
        hope this helps
        if you need more let me know
        GOLF V 2.0 TDI COMFORTLINE
        SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
          haha no no no! i need less! too many to choose from!
            We're running Mobil 1 0W-40 in our GTI and it seems to work a treat.
            Also, have a read of this thread...
            Hi all. I've just checked my engine oil level and I would need to top it up very soon. I wanna know which Castrol oil so I wouldn't 'corrupt' it. Is it the Castrol Edge or Castrol Magnatec 10W-40? Got the car from Camberwell VW at Burwood in Melbourne. Thanks all.
            Cheers Liam
            MY10 S3 3dr
              You shold allways use the highest specs oil for your engine. Owner manual will give you the right specs no. Go with the highest no. in that manual since it is the latest at the time you car was manufactured.
              The engine oil is cheap the engine is not.
              Label on the oil container must have writen "approved by VW" not made to VW specs. That means the oil was tested and given approval by VW. If the oil company didn't submit oil sample to VW for testing label will not say approved it will say: "Meets or excedes specs...." "Made to VW specs....."
              Performance Tunes from $850
              Wrecking RS OCTAVIA 2 Link
                Oil
                Hey dude, i work with these every business day(mechanic), and all i can say is fully synthetic 0w-30/40 whatever.
                Zender
                  If it is not approved, than you can use really whatever, even cooking oil which is also not approved.
                  Mechanic, ha you probably know better that VW if you advising "whatever".
                  I wouldn't want you changing oil in my car.
                    having a look at the thread minigolf posted i think ill go with the castrol edge 5w30 stuff. Its readily available as far as topping up goes and meets the necessary specs
                      we use fuchs gt1. 0w30 german engineered oil,
                      but hey i hav been looking for some fully synthetic cooking oil, monounsaturated if possible??????
                      hahaha
                      know any places?
                      Zender
                        I didnt get round to doing the change the other day but i just got an email. supercheap have castrol edge sport 5w30 on special at the moment. $29.90 for 5L
                        Supercheap Auto is Australia's leading auto spares, parts and accessories retailer stocking a variety of car batteries, air filters, coolants and more online or in stores nationwide
                          http://www.supercheapauto.com/products/catalogue.aspx
                          I reckon I'll grab some of that!
                          George
                          14 EOS 2.0 TSI has arrived!
                            That is insane cheap, like cheaper than most auto stores BUY IT!
                              I recently done an oil change myself.. after 2000kms taking on a new delivery.
                              Went to the stealership bought 5L of Castrol Castrol Edge Sport (with VW 50200/50500 standard) for $65 and new oil filter for $16. After the oil change.. the R is running better and 470km for a fulltank (instead of 420km fulltank b4 oil change).
