Mk5 Golf startup noise
  • Mk5 Golf startup noise
    Recently my Golf (1.9 tdi) has started making a short squealing noise at startup, only lasts 1-2 seconds and it sounds like its coming from the middle of the engine bay. It does it when the engine's hot or cold and sometimes after the initial startup the noise will come back after roughly 5-10 seconds in short 1-2 second bursts then go completely. Anyone have an idea what it'd be? thanks.
    It could be the dual mass flywheel (DMF). Get it checked.
    How many kms the car done?
    Performance Tunes from $850
    Wrecking RS OCTAVIA 2 Link
      its done 78000km
        Sounds like dual mass flywheel
          Had this noise on our TDI Jetta. It was a faulty starter motor and earth wire. Replaced under warranty.
          Edit: I see yours makes the noise even after its running. Probably not the starter motor then.
          MY20 Golf GTI TCR
          MY20.5 LR Defender P400 HSE
            Taking it in to the dealers this morning, hopefully it's not too serious...
            ---------- Post added 28-03-2012 at 07:04 AM ---------- Previous post was 27-03-2012 at 07:36 AM ----------
            Turns out its the starter and earth wire, which is covered by stat warranty...
