DSG Paddle Steering Wheel Retrofit in Sydney
  • DSG Paddle Steering Wheel Retrofit in Sydney
    Howdy Dubbers,
    I "impulse bought" a MkV DSG paddle steering wheel off ebay about 4 months ago (from memory about $180 incl shipping from Germany, without airbag), and since then I haven't really had time to get it around to getting it installed. So, as my DIY skills are useless, is there anyone in Sydney who can install it using the current airbag?
    Cheers.
    2010 B6 Passat 125TDI Black, leather, RNS510, boringly comfortable
    European Auto Tech installed mine for me... can't tell you the price as I had it done as part of the service
    Daily Drive: MY06 Jetta TFSI 2.0 DSG Shadow Blue, GIAC Baby-Extreme tune, APR HPFP, Eurojet 3" DP, Forge Twincooler, AWE CCB Intake, 18" OZ Botticelli, Pirelli PZero, FK SilverlineX Coilovers, DBA4000, Whiteline ALK & 24mm Rear Swaybar. Weekend Drive: Alfa Romeo 08 Spider 3.2L V6
      Fair enough, I suppose it's only 3000 km until my next service, so I may as well be patient and get it fitted then.
        Is your steering wheel the same as the one you bought with paddles?
        You Air Bags may or may not fit.
        I know the GTI wheel with paddles I bought, the air bag is completely differnet shape than the original wheel. (both wheels are new square button multifucnction style) - and will not swap over.
        I was lucky I got the airbag with the GTI wheel or else I would have been stuffed.
        \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
        ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
          I've checked the wheel and the airbag is the same shape. I didn't get a GTI wheel, just a normal (round-bottom) MkV style wheel with paddles, similar to those found in the MkV Golf GT Sport.
          If anyone's interersted: Original VW Golf 5 V Jetta Lenkrad Leder Multifunktion DSG NEU 1K0419091ES YRB | eBay
          Julius.
            when I did mine, the Jetta had the normal round multifunction steering wheel without paddles.
            The R32 flat bottom wheel with paddles fit perfectly without any changes to the air bag
              is coding required for the jetta retrofit or is it a simple swapover?
                Depends... Mine did not need coding as the paddles worked - but we used VCDS anyway to check the settings and turn on the bit.
