Hi, first real post....so here goes, had an evap lower limit fail that I managed to fix by replacing the N80 valve and hose myself, (happy with that) but a few months ago I had an issue with a constant battery drain, that turned out to be a water damaged electric door module on drivers side. This was replaced and all seemed well.
Until I got my VCDS cable and fixed the evap problem I wasnt aware that there was an issue with the safe motor on both front doors. I understand what this motor does but I believe the electric window module replaced wasn't coded in the shop properly so I would like to ask what It should be coded to on a MkV GTI my08 (German built).
I will try and attach my latest scan, I have also just tried to code it as 1680, to see if that helps....but I believe that it does have a safe motor installed correct?
Thanks for any responses
Chassis Type: 1K0
Scan: 01 02 03 08 09 15 16 17 19 25 37 42 44 46 47 52 56 62 72
VIN: WVWZZZxxx Mileage: 58980km/36648miles
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
37-Navigation -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 0010
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0010
Revision: 5BH16--- Serial number: VWX7Z0G43NN880
Coding: 040300431C070160
Shop #: WSC 66565 257 00032
VCID: 346318E32EAB
No fault code found.
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 043 Q HW: 02E 927 770 AE
Component: GSG DSG 081 1305
Revision: 04508010 Serial number: 00000704240216
Coding: 0000020
Shop #: WSC 44551 111 44551
VCID: 224FEEBB845F
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0004738
Shop #: WSC 00046 412 00000
VCID: 73E1DBFF6B25
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS
Component: ClimatronicPQ35 120 1111
Revision: 00120021 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 79FDE9D74949
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000007100958
Coding: E58D8F2700041500471400001400000000087F075C00010000 0000000000
VCID: 71EDD1F71139
Part No: 1K2 955 119 E
Component: Wischer 120707 020 0501
Coding: 00049109
Shop #: WSC 00046
Part No: 1K0 955 559 AB
Component: RLS 070507 020 0105
Coding: 00208933
Shop #: WSC 00046
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 T HW: 1K0 909 605 T
Component: 1P AIRBAG VW8 020 2300
Revision: 05020000 Serial number: 0038PD160U00
Coding: 0012624
VCID: 3D753DC71DE1
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 AQ HW: 1K0 953 549 AQ
Component: J0527 636 0070
Coding: 0012122
VCID: 810D0137A199
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K6 920 874 HW: 1K6 920 874
Component: KOMBIINSTRUMENT VDD 1216
Revision: V0002000 Serial number: VWX7Z0G43NN880
Coding: 0003103
Shop #: WSC 60074 959 65905
VCID: F0EB54F39A33
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 L HW: 1K0 907 951
Component: J533 Gateway H07 0052
Revision: H07 01 Serial number: 040607F1001408
Coding: ED807F065002020003
Shop #: WSC 60074 959 93514
VCID: 306B14F3DAB3
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 1216
VCID: F0EB54F39A33
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 680 D HW: 1T0 035 680 B
Component: RNS-MID H11 3970
Revision: AB001001 Serial number: VWZ6Z7Z5604521
Coding: 08010000010000020000
Shop #: WSC 42595 146 50733
ASAM Dataset: ------------------------- ------
VCID: 2F69178FC78D
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl
Part No SW: 1K0 959 701 M HW: 1K0 959 701 M
Component: Tuer-SG 006 120B
Coding: 0000640
VCID: 387B2CD332C3
1 Fault Found:
00096 - Drivers Door Central Locking (Safe) Motor (V161)
012 - Electrical Fault in Circuit
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 M
Component: EPS_ZFLS Kl.069 H08 1901
VCID: 366722EB38D7
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT
Component: KSG PQ35 G2 020 0204
Revision: 00020000 Serial number: 00000000000000
Coding: 819002005103087F2D04840570085FC690FC00
VCID: 83010B3FBB85
Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H03 1301
Part No: 1K0 951 178 A
Component: Neigungssensor 003 0203
Component: Innenraumueberw.003 0203
Address 47: Sound System Labels: 3C0-035-456.lbl
Part No: 1K6 035 456 A
Component: 08K Audioverst. 0005
Revision: 00003000 Serial number: 00000000136227
VCID: 2A5F069BFC6F
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl
Part No SW: 1K0 959 702 M HW: 1K0 959 702 M
Component: Tuer-SG 005 090B
Coding: 0000640
VCID: 397D29D709C9
1 Fault Found:
00097 - Front Passengers Central Locking (Safe) Motor (V162)
012 - Electrical Fault in Circuit - Intermittent
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
VCID: 2F69178FC78D
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 K HW: 1K0 959 703 K
Component: Tuer-SG 006 1201
Coding: 0000144
Shop #: WSC 00046 412 1012557
VCID: 387B2CD332C3
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 5K0 959 704 HW: 5K0 959 704
Component: Tuer-SG 007 2106
Coding: 0000144
VCID: F2EF5EFB943F
End ---------------------------------------------------------------------
VCID: 346318E32EAB
Coding: 0000020
VCID: 224FEEBB845F
Revision: 00H11001
Coding: 0004738
VCID: 73E1DBFF6B25
VCID: 79FDE9D74949
VCID: 71EDD1F71139
Coding: 00049109
Shop #: WSC 00046
Coding: 00208933
Shop #: WSC 00046
Coding: 0012624
VCID: 3D753DC71DE1
Coding: 0012122
VCID: 810D0137A199
Coding: 0003103
VCID: F0EB54F39A33
VCID: 306B14F3DAB3
VCID: F0EB54F39A33
VCID: 2F69178FC78D
Coding: 0000640
VCID: 387B2CD332C3
1 Fault Found:
VCID: 366722EB38D7
VCID: 83010B3FBB85
VCID: 2A5F069BFC6F
Coding: 0000640
VCID: 397D29D709C9
1 Fault Found:
VCID: 2F69178FC78D
Coding: 0000144
VCID: 387B2CD332C3
Coding: 0000144
VCID: F2EF5EFB943F
