I was driving along normally today when I suddenly got a STOP Low Oil Pressure warning. By the time I had pulled over the warning had stopped. I stopped the engine for a minute, restarted it with no further warning.
I was about to drop into my local VW mechanic anyway so they took a look at it while I was there. Oil level was fine; no error codes and no obvious cause or solution.
They recommended that they drop the sump and check the up-take/pick-up thingy for blockages as taking a punt that it's only an error with the sensor etc rather than an actual oil pressure problem seemed too risky a gamble.
The problem has only come up once and only a few mins before I had it looked at. As an oil pressure issue has the potential to have serious consequences, I'm taking this seriously.
Car is 2005 FSI, only 51,000km so you wouldn't necessarily think it would be oil pressure but you never know.
Anyone else had a similar experience? What did they do about it?
