I noticed a audible "clunk" when the DSG shifted into 6th gear. I was going slow, probably ´round 50km/h. No hard acceleration. Strange thing is that this noise only occurs from 5th to 6th gear only.
Interesting thing is that the noise doesnt occur when accelerating, only when crusing and dsg automatically changes from 5th to 6th at low speed/rev range
Would you consider this part of standard DSG operation "noise" or would it be something for the dealer to look at?
Anyone else experiencing the same issue. Ive searched around on other forums and it does appear to happen with others as well but no exact solution to this fault. A member on R32OC got his mechatronic and gearbox changed under warranty and the thud was still there from 5th to 6th gear at low speed range
The only answer i found (however no update if the software update fixes the fault):
"dropped the car to the agent and after a week of investigation with Germany
thy agent said its normal Because i decided to upgrade the flywheel to fix the gear rattling Issue (More Info ) , u will only hear the noise if you go into 6th in the speed range of 40-60 km, and Germany is working on a software upgrade
in short , R32's which Wr Produced in Jan 2008 will have the "Thud Noise" bcoz Vw Germany Upgraded the Flywheel for the 2008 batch,
and R32's with a certain batch of Chassis number Will not have the "thud" nstd thy will have the Gear Rattling Problem unless the owner decided to fix the Gear Rattling issue"
---------- Post added 08-11-2011 at 05:19 PM ---------- Previous post was 06-11-2011 at 09:21 PM ----------
no one with an answer or any ideas?
