Originally posted by neksmerj
View Post
Picked up my first Golf today
Yes you will but if you go down to the local VW dealer chances are they might be able to look up your VIN code and get you the code, if not you'll have to pull the radio out and get the serial number off the radio and again the dealer can find out the code for you using that serial.2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
Hi SS3000,
The key would not physically turn in the lock, but appears to be ok now. I sprayed some WD40 into the lock and ran the key in a few times.
With a bit of jiggling, it finally turned. That was last night, I haven't tried it again this morning.
Ken
haha, WD40... won't go there, good luck with that.Originally posted by neksmerj View PostHi SS3000,
Ken
Check out the owners manual and search posts on the forum, you'll find quite obvious answers to most of your questions very quickly. There should also be battery specs in the manual, otherwise call any battery retailer and they'll help you out with the right battery, call around as prices can vary significantly.Track Car: 06 Polo GTI Red Devil mkII
Daily: 2010 VW Jetta Highline
Whilst I appreciate some members saying "use the search function" have you tried? You finish up with posts that have absolutely no bearing on the question.
Perhaps I'm pedantic, but I was shocked when the VW logo fell off the back of my car key case. Can new ones be purchased from VW?
It's an aluminium disk with a sticky back about 15mm in diameter with the VW logo in blue. It hides a screw in the case.
Another question. What does AGCOM stand for and what is it? I know, you'd reckon I had better things to do with my time.
Funny how you go down the street for some shopping 5 mins away, and return home 2 hours later taking the long way. What a great drive!
Ken
Hmm, works flawlessly for me. I use it frequently and it's very accurate. Make sure you're using the Google custom search bar at the top left. For example, I typed in VW key emblem and this was the first hit - http://www.vwwatercooled.org.au/foru...ore-61284.html - which hopefully answers your question. These key emblems were pretty average quality on the mk5; I've already replaced mine once.Originally posted by neksmerj View PostWhilst I appreciate some members saying "use the search function" have you tried? You finish up with posts that have absolutely no bearing on the question.
KenMY07 GOLF GTI
5-Door l Tornado Red l DSG l Leather l Xenons l MFD2 l TCP T.B.E l DNA stage 1
This may not be the appropriate area to ask, but here goes.
Many years ago, I had a brush that fitted onto the end of the hose for washing the car. It had a tap on it to reduce the flow. From memory it was made by Nylex. Like so many good giggers, it's gone AWAL and I want to replace it.
The Nylex web site does not seem to list it, and a check with eBay turns up zilch. Don't want a rotary one, just a fixed head.
Any clues?
Ken
Replacement VARTA battery?
Can we nail this once and for all.
I want to talk about batteries. The OEM battery is a VARTA fully sealed unit in my 2006 Golf 2.0 FSI Comfortline. Stickers on top are as follows:- 12V 70Ah 340A DIN and 570A EN/SAE and VAO and 1 J0 915 105 AE.
I have looked at the VARTA web site, and can't find a matching No. This suggests that this battery has been superseded by a later model.
If this is the case, please tell me what the equivalent VARTA code No. is for a replacement battery.
Are these batteries more than a barrow load of gold bars? In the UK, they are around 65 GBP eBay, but that's over there.
I have not checked with a VW Dealer, my wheel barrow of gold bars is probably far too small.
Get talking,
KenLast edited by neksmerj; 03-10-2011, 09:44 PM.
AutoPro, Super cheap will have something like that.
Maris
Originally posted by neksmerj View PostThis may not be the appropriate area to ask, but here goes.
Any clues?
Kensigpic
Battery World?
Maris
Get talking,
Kensigpic
Finished up buying a genuine VARTA battery via a VW dealer. It's identical to the old one except it's 72Ah instead of 70Ah.
VARTA 000 915 105 DG
12V 72Ah 380A DIN 640A EN/SAE
The cost:- $306 all up. I have read reports of them being well over $400, ouch!
Supplied and fitted by vw_tech, one of our members. Couldn't meet a nicer, more enthusiastic bloke.
Many thanks,
Ken
Road noise?
Had my 2006 Golf 2.0 FSI Comfortline for 3 weeks now, and I'm stocked. Not a bad gigger eh?
I have one issue though, road noise. I may be wrong, but I think the tires are Dunlop Eagles. The tires are what ever VW fitted as standard. I have had the tires checked over, and the tire dealer could'nt find any obvious fault.
The tires are noisy, even at low speed. Almost need earmuffs. Is this normal? Is there a tire that runs more quietly?
Ken
