GTI MK V brakes on a MK V 2.0 TDI
  • GTI MK V brakes on a MK V 2.0 TDI
    Hi does anyone know if the GTI MK V rotors and calipers will fit a MK V 2.0 TDI with 16 inch wheels?
    Cheers.
    Can't say for sure but I doubt it, get some 17s.
    Golf GT Sport TDI
      I'm in the middle of this exact swap on my GT, so can give you a front brake dimension, the rears would certainly fit.
        Find someone with a GTI and give them some beer to test bolt your wheels on.
          I thought the GT already had GTI brakes? I was under the impression the only thing different was the suspension in the GTI was slightly lower and firmer.
          MKV GTI
            Exactly what I heard too - at least I'm under the impression the front brakes are the same ( apart from not being red ) but the rears are definitely different to a GTi- little confused why Greg would be be putting GTi brakes on his GT if this is the case - unless of course he wants the GTi rears.....personally If I was to change the brakes on my GT it would be either an upgrade to R32 specs or some aftermarket Brembo's.
            2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
              Yeah he's putting GTI rears on. GT uses stock Golf brakes i.e. tiny.
              I've done it. It's pretty easy.
                Did you buy some R/R32 fronts Ben? I thought I saw a thread in the For Sale where u said you would take some but can't find the thread.
                Theres some for $1k on vwgolf.
                Golf GT Sport TDI
                  Nah I got beaten to it. Spewin.
                  Yeah I saw those as well...
                    Lads the fronts are indeed the same, I am putting on the much newer MK6 GTI front ones just because my fronts are 3/4 gone, and I could paint the new second set properly off the vehicle a nice wanna-be R32 blue.
                    The rears are an inbetween size on the GT, and mine are paper thin, JMac has been up me more than once about them. I decided to grab some GTI ones ( thanks to benough ), as I'd prefer to have all the GTI pad and rotor options when these wear out, rather than the limited GT specific options.
                    Why you'd want even more brakes is beyond me, the stock GT's have one amazingly good stop in them, I've had to use it on a few occasions, and have been astounded that it stopped so quickly! For the track sure....but that's a rare thing for most people!
                      Honesty? Wank factor. I just love the look of a big set of calipers and rotors filling up the wheels, I'm certainly not complaining about the stopping power of the stock GT brakes.
                        Hi Greg,
                        I erroneosly bought a set of Hawks GTI pads thinking they all fitted. Ive just been quoted $160 here in Aus for the correct rear GT pads, are you interested in the new GTI rears i have ? Or anyone else?
                        Steve
                        Current:12 Golf GTD, Mods on order -Bluefin Remap, Mods planned-plenty
                        Former:08 GT Sport TDI DSG Bluefin, HPA SHS Coilovers,H&R Swaybars with Whiteline Adj Links
                          Cheers.
                          Should be fine.
                          Skoda Octavia has the same setup & few of people on Briskoda have done the upgrade using 16"s.
                          The calipers & pads are the same, you just need the bigger discs & the GTI carriers.
