Hi all
As some of you already know I am having issues getting VW to replace my mechatronic unit and I am not the only one..
The issue is that they will do anything to avoid replacing the unit, including trying to convince you that they are normal characteristics. I've had a read through some of the stuff posted and been in contact with some of you, and I can see that some of the issues/errors happening with the DSG are mostly different. In my opinion, that is probably why they are always not sure where the problem is coming from..
I've been in contact with Volkswagen Australia and their "Customer Care" department (since November 2010), which I personally think gets paid to make you think you are important.
Firstly, they will tell you that you require a Technical Report from a VW Dealership, which you need to take you're car to and leave it for a day to get diagnosed. Speaking to a contact at VW, there is no such thing.. They only look at the issue and if it is not in the "Technical Product Information" they do not lodge a ticket.
So then they come up with a blunt reason "they are normal DSG characteristics". We all know this is not true.. and most of us have been driven in other VW's with a DSG unit that doesn't have the same issues/errors. If you do request to test another identical car and prove it is not a normal characteristic, they will come up with an excuse - at least they did for me!
I guess it helps going to a few VW Dealerships and getting an opinion from each foreman, but do we really want to waste days off work, add unnecessary kilometers and waste fuel?
Also, a third party technical report would assist, confirming there is an issue with the Mechatronic Unit. Not sure how this would be obtained? Any suggestions are welcome!
"The issue I am having is that there is a "thump" sound every time the DSG changes into 6th gear. Also, an occasional "bang" coming from the engine, upon ignition."
Volkswagen Mechatronic Issue - Article
Volkswagen recalls 53,300 new vehicles, announces service program to address DSG complaints | autoinsane
Looking forward to everyones view on this..
