Fuse/electrical
  • Fuse/electrical
    Hey guys,
    I blew an interior light fuse yesterday and I went to change it today. While searching for the blown fuse I pulled out all the other fuses. Once I started the car the drivers side power windows mirror indicator and central locking cease to work?
    Does any one have any suggestions on what it might be?
    Originally posted by chiefy_maca View Post
    Hey guys,
    How did you remove them, one by one or did you remove the lot.
    I usually start at one end remove inspect and replace if the fuse is OK ,if its blown replace that fuse before continuing to the next one.
    There's a lot of empty fuse's one can easily put a fuse in the wrong holder.
    Look in your owners hand book there's the layout for the fuses and what there for .
      I did as you said remove one then replace I just can't seem to pin point the problem
        There are two locations - behind round light switch and in the relay box next to the battery. Did you go through both?
        2005 Golf V 2.0TDi DSG U/Grey S/roof - SOLD
