I followed a couple of other DIYs found on the net, but figured seeing an Aussie version of this might be of use to some people as well. For a bit of background it might pay to read the other DIYs if you find any gaps of information in my write up:
4string on VWvortex
KuniD on uk-mkivs.net
Tools required
You'll need some sort of plastic card or prong to pry open some of the bits and pieces. I used an old credit card. You will also need a Torx20 screw and ratchet attachment.
Step 1
Start by removing the panel around the top mounted dash vent dial (already removed in this pic). I just pried it up with an old credit card and managed to carefully remove the clip. Then, as you can see, started to gently force the vent cover with a small screwdriver. Once you have all the clips unhooked and the cover is free, remove the A/C sensor wire.
Step 2
There is a torx screw at the top of the next panel for removing (indicated by white circle). Haha, be careful not to drop the screw into the dash below! Damn, I missed a photo of removing this piece. Once you've got a clip or two released you can pull this one out with a reasonable amount of force. But if you bust any clips, it's not my fault okay! The second image was taken after the panel was removed and you then need to unscrew the two torx screws in frame to prepare for the next piece to be removed.
Continued...
4string on VWvortex
Tools required
Step 1
Step 2
Continued...
