Cruise Control Problem
  • Cruise Control Problem
    Hmmm had an issue with the Cruise Control in my GTI yesterday.
    Basically the on/off switch didn't work. Nor did the cruise control dash indicator light up.
    Restarted the car, no problem.
    Any known faults and/or easy fixes for this?
    MY07 Red GTI 3 Door
    Had the same problem. Got the stalk replaced under warranty.
    Dan
    Dan
    2020 White Silver T-Roc Sport
      If you or any of your mates got VCDS cable, run a scan through to see if there was a fault code.
      If you don't have one or can't get hold of one, take it to the dealer and ask them to scan it for you. If it didn't work once, would have thrown a fault code.
      2009 .:R32 • 5Door • Black Magic • DSG • Sunroof • Stubby Antenna
      2007 Honda CBR1000RR Fireblade • Yoshimura RS5 Carbon Fibre Pipe
        pretty sure this was a common fault ages ago... seem to recall lots of people on here complaining of their cruise control stalk not working then working next time the car was used... my jetta also did this for a while and had the stalk replaced under warranty, dealer was aware of the issue and had changed a few of them.
          i currently have this issue, exactly the same and took it to VW, they found a fault code.. quoted $400 to repair. i purchased my car about 6 months ago from essendon VW, thought i would be covered under warrenty?
            that's no good..
            the issue is the car is now out of warranty.
            I've never even used the cruise control, so it may be been faulty since it was in warranty.
            Well, I'm taking my car to South Yarra VW for a coil pack recall next week and will discuss with them, if they will fix the indicator for free on the basis of goodwill.
            jsof, that sounds unlucky, especially 6 months ago from a dealer. My car was purchased there, so no point taking it back there.
            MY07 Red GTI 3 Door
              Originally posted by Johnbu View Post
              that's no good..
              It doesn't matter when you bought the car, if it's within the 3 year warranty the item will be covered by warranty. If it's out of factory warranty, you have a 3month/5000k statutory used car warranty. But as you're at 6 months, that warranty is also expired.
              Also, it doesn't matter if the device/switch/item was never used in the first 3 years - if the warranty is expired, the switch is no longer automatically covered. Same as if you only travel 60,000 in that time, the last 40,000k of possible warranty is forfeited.
                yeah I understand... hence my hope of goodwill comment
                MY07 Red GTI 3 Door
                  Cost of extended new car warranty - about $1500, less $400 for cruise stalk replacement - net cost of warranty $1100.
                    What is the recall for the coil pack?
                      Recall on gti coil packs.
                      MY07 Red GTI 3 Door
