Originally posted by Transporter
View Post
So, now forget that they have all the software and computers to help them to design the engine and the car that will last with minimum failures.
As you said, they have first hand experience seeing failed component (timing belt). Don’t you think that it is a lazy approach to solve the problem (timing belt failing) by reducing replacement interval from 120,000km to 60,000km. I would make changes to the components instead. Especially if they claim that they care about the environment.
But hey that’s me using common sense.
What I think is that someone who poorly designed it at the first place is applying his knowledge to get the solution to the problem “replace the timing belt at the 1/2 of the specified interval”, done presto problem solved, lets work on the next model.
