Hi everyone,
A couple of months ago I "went German" and bought my first VW, a Jetta 125TDi.
Unfortunately it has a problem, but being hard to reproduce, the dealers will not conduct any thorough investigation until they can see the symptoms. They did confirm there were no engine fault codes logged by the computer and at least tried driving the car several times during the day. I just thought I would ask here to see if anyone else has had this issue or can suggest things I can try to confirm what the problem is.
The problem is that the car "lurches", as if the engine is mis-firing or mssing, although it could be other causes. This can become very severe, and accompanied by a "clunck" from under the bonnet with each lurch. The problem is very specific: it only occurs with very low RPM (about 1200), and a very small amount of throttle applied. It also seems to be more prevalent at certain times of the day and rainy weather seems to make it much worse. It also seems to be more prevalent when the engine is warming, and the temperature gauge is at about 9 o'clock. At about this time, the idle can get rougher than usual. Applying no, or larger amounts of, throttle stops the lurching, and I have also found that if I swap to "manual" and select a lower gear, this also fixes the situation. Swapping back to the higher gear then causes the lurching to start again.
A you can see, there are a list of conditions to make this happen, but the annoying thing is that a couple of hills on the way home from work that pretty much always trigger the problem so I experience this virtually everyday. Unfortunately, these hills are no where near the dealer.
I am loving the fuel economy, but if it could refrain from jumping like a kangaroo at times, I would be much happier. Thanks for any information you an provide.
Best regards, Jeff.
Best regards, Jeff.
