2.0L TDi Tech Details
Pure Gold!
.... And so much for the simplicity of diesels
There's just so much that can (and eventually will) go wrong! Thank God for:- A 3 year warranty (but what about after that? An extended warranty?)
- My old Mk1 GLD in the shed
Thanks jets and maris. You've done well. Now to the printer! Phaeton... find part 1 and fix your scanner. Might as well have some more scary stuff
Top article, thanks for making it available.
Interestingly enough, if the cruise control is engaged and you change gears say from 5th to 6th, there is a ( slight ) surge in the rpm.
According to the information ( if I have interpreted it correctly ) this should not happen ?
Have now travelled 5,300 ks in the 1st month of ownership - what a car !
cheers
richo
2007 2.0TDI Golf
Surging cruise control
I've only just started using cruise regularly (12750km) and yes, I experience the surge but in other gears too. I find that as I set the speed there is a surge to a speed slightly above where I want it to be. My wife had a Mazda 929 and it did exactly the same thing. When I had the TDI's ECU reprogrammed to solve the battery flattening problem I asked the techie about it and he said it wasn't normal but couldn't find why it happened.Originally posted by jackafrica View PostInterestingly enough, if the cruise control is engaged and you change gears say from 5th to 6th, there is a ( slight ) surge in the rpm.
Excelent find.
I don't know if you found this nice info?
Latest news coverage, email, free stock quotes, live scores and video are just the beginning. Discover more every day at Yahoo!
There is a book by BOSCH:
Diesel - Engine Managment system and components (ISBN 0-7680-1343-7)
which has a lots of detailed informations. I've bought it from motortraders.
I'm not sure if you can borough it from the library.
I'm going to buy erwin acces to Golf V, I've had Transporter 5 from erwin for a one year I've printed out and converterted to PDF files.
I've got VAG-COM if somebody needs scan or change door unlocking etc.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
Where can you buy it?Originally posted by MRL T5 View PostExcelent find.
is information in it referring to current TDI engines?GOLF V 2.0 TDI COMFORTLINE
SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
