Wokwn.. when you say it takes long to heat up.. are we just talking about the fan ?
What if I have the AC turned on max heat? Will that will warm up the car on a cold winters day quickly?
If your car coolant is hot, you get heat instantly (e.g. parked for less than 4 hours).
Once your coolant is hot, yes it has heaps of capacity to heat the car. Bear in mind that the climatronic system in VW tries to supply 'gentle heat or cooling'. People often complain that the aircon isn't cold or the heater isn't hot as the air coming out of the vents isn't specifically hot or cold but if they put a thermometer in the car they find that the climatronic is maintaining the set point they selected. If you put it on 'hi' or 'lo' you get searing heat or icy cool.
For an example, today it was 3.5 degrees in Thomastown VIC where I live. I drove from there to the Melbourne CBD which took around 45 minutes. I had warmish air blowing in 4 kilometers (approx 10 minutes including traffic lights). By that time the coolant was up to 50 degrees.
It didn't reach normal temperature (90 degrees) until about 1km before I reached my destination, but I got useful heat in about 10 minutes. Not face searing heat but useful warming heat.
Also my short trips are to pickup and drop off mrs from the station.. thats about 1km away, 5 -10 mins round trip including waiting time. Too short?
Also note that they won't really heat up much if you start it and then idle it for 10 mins before driving. This is actually bad for the engine as it causes cylinder glazing.
The think about a diesel engine is that it is so efficient. It is the waste heat from an engine (up to 60% of an engine's output in the case of petrol) that is used to heat the cabin of the car. Diesels don't produce as much waste heat and the engine is physically denser (i.e. more metal to heat up too) so you don't get as much heat out of them. Exhaust temperatures are way down on a petrol which leads to longer turbo life as well.
Work is about 15 mins drive, 7kms away, but i take the "scenic" route cos i like my driving and cornering..
Bizi - Im wanting a manual not only to avoid cost of DSG servicem but because i love clutch/shifter action and blipping the throttle as i drive.
Looking at a Diesel's narrow torque band.. im guessing no one blips / heeltoes on these cars?
You look at the narrow torque band from the point of view of a petrol engine that can rev to 6000RPM. sure, 1750 - 3000 is small for an engine that can rev out to 6000, but your diesel engine red lines at 4500. So as a percentage, that torque band is actually most of the rev range and also the area people usually drive petrol engines as it feels 'comfortable'.
Your problem with spirited driving in a manual will not be the narrow torque range (except in first gear), it will be preventing wheel hop in 1, 2 and 3rd gear (and 4th when raining) when the torque suddenly comes on and your left hand is busy with both changing gears and using the indicators. Unless you live in Victoria where indicators are optional at all times.
AND DAMN its hard to fine a Manual TDI!!
On car sales theres like 3 in sydney, none close to me, all not the color I want.. i gues thats the pain with buying used
Looks like theres nothing to check out this weekend.
