lots of smoke....no power...
  • lots of smoke....no power...
    guys on behalf of a friend.
    last week the light on dash turned on for the Air FLow meter. he took it off and cleaned it with spray and reset it...after a couple of hours it came back but the car was not pulling as usual and quite a bit of black smoke coming out of exhaust. he put another 2nd hand AFM he had in garage and reset the fault but after a few hours still came back and still not pulling right.
    so ordered a new one. light was off for 2 days but it then came back on....
    the car is not pulling hard as usual....he can press the pedal all the way down but the car accelerated slowly and lots of black smoke out the back.....
    any ideas?? its a 2007 1.9 TDI... cheers
    someone on another forums suggested maybe clogged DPF...
    1991 BMW 318is RED E30
    Yep lots of smoke then not enough air, check your intercooler hoses for security, the air to diesel match is wrong, also it isnt pulling would indicate to me an intercooler hose has dislodged itself. Had a 1.9 do that for me was the lower hose.
    If the DPF was clogged would be hard to be exhausting gases surely
    You confidently say air flow meter, have you got codes??
    Jmac
    Alba European
      How can it be a clogged DPF? The first VW with DPF was the GT Sport TDI IIRC with the 125kw 2.0 from MY08 onwards.
      website: www.my-gti.com
        Thats correct so moving along back to lack of air mate, check your intercooler hoses
        Jmac
        Alba European
