Car Horn - why does it not work when the car is off?
  • Car Horn - why does it not work when the car is off?
    Anyone know why the horn doesn't work when the car is off ?
    Can it be enabled by the dealership via the vag-com?
    Reason i ask is that i was waiting outside my wifes work when someone trying to reverse park in front of me actually backed into the GTI
    I tried beeping the horn before it happend but it doesn't work when the car is switched off.
    Luckly the number plate cover took the impact and there are no scratches or marks on the car.
    Retarded people who can't park a car properly - gotta give you the ****es eh? I've never seen an option in VAG-COM to enable/disable the horn with the key off?!? I think a lot of European cars are set up like that though - I remember Escorts and Cortinas (and even some Falcons) in the 70's had horns that only worked with the key on.
      Don't worry dude works like that in the mk3 aswell
        Yeh the horn in my Magna also doesn't work when the ign is off.
          My rice burner is happy to make noise, turned on or not.
          I have my RED , 3DR MKV GTI with leather in manual and I love it!
            carry an air horn in d car
              Actually, I reckon set up a compressor/air tank and a big juicy truck air horn (if you can find somewhere to put it!). That'll work, regardless of key position, and scare the ****ter out of the tool who just about hits your car!
                VW Horn wired to work only with ignition on
                That's how VW's are wired: certain functions only with the ignition on. Its not a thing you can alter with programming.
                You could do a direct feed to the horn, say from the battery. The horn button earths the circuit, so it would then work whenever you hit it.
                Paul
                  These would be ace
