As indicated by Buckets the diffuser is the path of least resistance & so most of the air flow that normally goes through the two centre face vents will go through the diffuser when the diffuser is open.
The comment you made: "If I use footwell + front, it will go to footwell + diffuser unless I manually shut off the rollers on the diffuser." is correct. Except that I would add that it also goes to the two outer face vents as well.
I'm sure the face vent button is only there to use in combination with other buttons, that the default air flow, when no buttons are pushed, is via the face vents & that the two centre face vents & the diffuser are connected and the combined air flow between them is controlled soley by the roller.
