R32 and GTi part numbers
  • R32 and GTi part numbers
    Hi guys.
    I'm looking at getting an R32 rear end for my GT Golf, along with some Gti side skirts and have been advised that I need the following parts to the do the conversion - ( prices are from the dealer )
    1K6-807-433-E-GRU (rear lower valence) - $835.36
    1K6-807-568-9B9 (exhaust surround) - $77.80
    1K6-807-739 (LH mounting bracket) - $12.90
    1K6-807-740 (RH mounting bracket) - $12.90
    1K6-807-251 (foam insert) - $84.70
    1K6-945-105-A (LH reflector) - $14.03
    1K6-945-106-A (RH reflector) - $14.03
    1K6-807-441-E-9B9 (tow hook cover; round) - $13.50
    Does anyone know if I need anything else or if I actually need the foam insert?
    With regards to the GTi side skirts, I've been advised they are -
    1K4-853-859-9B9 - $148.65
    1K4-853-860-9B9 - $148.65
    Do I need any other parts to fit these? My GT does not seem to have any mouting holes for this so I was just going to secure it with the two end screws and some double sided tape.
    One interesting things I found is that I've read that you can also get the R32 side skirts which are identicle apart from the fact that they are primed smooth and ready for paint. I was under the impression that this would make them more expensive but If I've got the part numbers correct it seems they are cheaper ( plus the left is cheaper than the right? )
    1K4-853-859-D-GRU (LH side primed; 4-door): - $135.13
    1K4-853-860-D-GRU (RH side primed; 4-door): - $148.58
    Finally - I want to get the lower lip section from the 2 piece lower spoiler off the GTi - the GT only has the upper section of that lower lip.
    From what I can tell the part I need is
    1K0 807 110 9B9 ( lower lip spoiler ) - $241.60
    Can anyone verify if all this is correct?
    2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
