Instructions...
  • Instructions...
    hi guys...
    I haven't been here for a while... been busy playing with my 12 month old son
    My warranty is about to expire, soon, so I am going to do my own servicing and brake replacement.
    I tried searching for it but came up empty handed...
    Can you please give links or pdf instructions on how to
    GOLF V 2.0 TDI COMFORTLINE
    SAY NO TO INTERNET FILTER http://www.getup.org.au/ http://nocleanfeed.com/
    Can anyone help pleae
      Brakes are easym, buy some pads from GSL rally sport, you'll need a 18mm socket (a breaker bar is very handy!) and a tool to compress the calliper back in.
      in your in bris you can rent mine, or you can buy one from america (ecs tuning + $50aud + delivery)
      As for the oil, never done it, but I'd be buying a quick release plug to put into the sump for when I do.
        Minor servicing you can do yourself, but for major stuff it's well worth the cash to use an aftermarket VW specialist. Replacing a timing belt is something I've done before, but would GLADLY pay someone else to do.
        If you search my tinkering begin thread it goes into replacing the oil filter, draining the oil is basically undoing the lowest large bolt on the alloy sump, best done after a run while the engine is still warm, not hot!
        If you're not quite sure about oil etc, best you don't start with important items such as brakes, just quietly!
          From the questions your asking & if you can't find the information using google, then I'd think about paying a decent independent to do the work.
          /Looks at photo
            Try this
            Meat's Brake DIY (w/ thanks to Dan GSR) DISCLAIMER: Neither I nor any other members who have lent their advice or expertise to the writing of this DIY take any responsibility for any damage to personal property or injury to yourself... Tools needed: - 2 ton Jack and jack stands (preferably 4)...
              Originally posted by 85Fuego View Post
              That is good one... What about servicing
                I typed in Golf GTI oil Change & the first hit is a pdf with photos.
                http://www.?????????????.com/gti/doc...Oil_Change.pdf
                seriously, how hard is it to use google rather than treat your fellow forum members like librarians?
                  Slightly different for diesels......
                    my apologies. I assumed you had a GTI for no particular reason.
                      No problems...
                      Can someone please explain why is it important to pour 200ml of oil into oil filter...
                      I would really like to know because mine is out of warranty, and I don't want to do any damage by not doing it correctly.
                        No problems...
                        It gets the oil through the system quicker & the oil pressure comes up faster.
                        Also (in theory), the preoiled filter is less likely to be damaged by new oil belting into a void at first start. eg the prefill acts as a damper. Not totally convinced myself.
                        100ml - 200ml - I doubt the quantity is hugely important.
                          Thank you Brad
