Rear wheel bearing for Golf
  • Rear wheel bearing for Golf
    Hi all,
    I have a rear wheel bearing that has gone on my 2.0 TDI .. VW wants $450 for a replacement ..
    Does anyone know an online supplier of these? or know where else I can get one cheaper?
    Cheers all!
    2005 Golf V 2.0 TDi DSG Silver S/roof + SATNAV + Leather.
    Originally posted by b1llyb0y View Post
    Hi all,
    Cheers all!
    Bazzle
    Prev 2008 R32 3 door DSG.
    Prev 2010 S3 Sportback Stronic.
    Now Lexus IS350 F Sport
      Hi Bazzle,
      Looking at their site, they dont support the BKD engines as these were never delivered to the USA.
      I dont know if they therefore would have any wheel bearings for my model?
        Tony (kinezo) just recently had his done.
        shoot him a PM and ask him.
        84 MK1 GTI
        01 DC2R
          Thanks for that, have sent him a PM.
            My money is on them all being the same on normal Golfs.
            Bazzle
              Unless it Specifies R32, they'll all be the same.
                Hi all,
                Cheers all!
                I have a noise coming from the rear and I'm not sure what it is.... What does the sound of a failed or failing bearing sound like?
                SPoddy
                2020 Tiguan 162TSI R-Line
                  A bit of a whine or whirr that may change note as you load up when turning.
                  Bazzle
                    Thanks Bazzle, I'll have it checked out as that's what it sounds like to me.
                    The car is due for its 60k service in a month or so but it runs out of warranty before then so I'll have to get it looked at sooner.
                    Regards,
                    Steve
                    SPoddy
                      A lot of people suspect a wheel bearing when it is actually scallop type wear on a tyre (particularly on a VAG car's rear wheel). A quick way to tell is to swap wheels front to back and see if the noise moves with the tyres (or increases/decreases).
                        A noisey wheel bearing will generally have a lot of free-play in it, too.
                        So, while you've got the car jacked up, grab the wheel at 12 and 6, and try to rock it in and out. Also, turn the wheel slowly, and listen for a rumbling noise.
                          Regards,
                          Steve
                          Hi Spoddy, long time no hear! As you've mentioned running out of warranty, not a bad idea to buy the VW extended warranty package. With a bit of haggling you should get it for around $1,400 for an additonal 3 years but needs to be purchased before warranty expires.
                          George
                          14 EOS 2.0 TSI has arrived!
                            I backing this post, my Jetta has had road noise when the tyre tread is low on both front and rear, different road surfaces have different sounds.
                            Worth a try swaping tyres around.....
                            The Bug
                            The VW Bug
                            2010 Golf 2.0 103kW TDI Manual White
                            2011 Multivan 2.0 132kW TDI Sliver
                            2018 Multivan 2.0 TDI White
                              George
                              Hi George,
                              It has been a while, I look and learn regularly tho .
                              I'll seriously consider this even though most studies show paid extended warranties are a businesses biggest profit earning product... just that we are dealing with VW here; not because they are unreliable but because they encourage us with expensive repairs...
                              Greg and Bug, I'll rotate the tyres on the weekend and see how it goes.
                              Cheers and thanks,
                              Steve
                              SPoddy
